Solid-fluid Interface question
Old   May 21, 2009, 18:13
Default Solid-fluid Interface question
Prashanth
shankara.2 is on a distinguished road
Hello
I am trying to solve for conjugate heat transfer on a solid coupon with film cooling holes. My geometry is shown below:
The purple outline is my solid with film cooling holes. I believe there are 5 INTERFACE faces here. The top and bottom faces of my solid and the 3 circumferential faces of my film cooling holes. All Interface faces are just single faces shared by both solid and fluid volumes. I meshed these faces first and used a size function to grow from these faces into the solid and fluid volumes. How do I specify the Interface in GAMBIT? I tried the following 2 methods but I'm not sure which one is correct.
1) Assign WALL BC for all 5 Interface faces, export mesh to FLUENT. Once I did this, FLUENT created a shadow zone for each of these faces. Here's my problem. I can see the face and its shadow listed in the BC panel but they are not listed in the Grid Interface panel. How do I specify COUPLED option for the face and its shadow? The BC panel shows all options for the shadow face and only the Momentum tab enabled for the original face.
2) I assigned INTERFACE BC in GAMBIT for all 5 faces with solid on one side and fluid on other. Now I can see these faces listed in the GRID INTERFACE panel but there are no shadow zones created. Also the Grid Check failed with the message 'Unassigned interface zone detected'.
Please let me know how to work around this problem.
Thanks
Prashanth
shankara.2 is offline   Reply With Quote
Old   September 14, 2011, 12:47
satyendra
satyendra is on a distinguished road
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
satyendra is offline   Reply With Quote
Old   September 14, 2011, 12:49
satyendra
hi prashanth,
i am facing exactly the same problem. have u been able to solve this problem?..
satyendra
fluid or solid ??? Krish FLUENT 1 June 24, 2009 04:38
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
BC at the interface of the fluid and solid manohar Siemens 3 April 8, 2005 11:34
Conjugate Heat Transfer between fluid and solid Li Yang Main CFD Forum 8 March 27, 2004 11:05
Material properties for fluid and solid David Baker Siemens 0 August 26, 2003 01:57
