Drawing a Semi cirlcle 3d
Old   December 21, 2009, 03:10
Default Drawing a Semi cirlcle 3d
Sherif
sambayo is on a distinguished road
hi ,
i want to draw a semi circle then extrude it to form a half pipeline attached is a picture of what i want to draw any suggestions ?
thank you for you help
sambayo is offline   Reply With Quote
Old   December 22, 2009, 01:22
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
whith gambit?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   December 22, 2009, 01:33
Sherif
yes i am using gambit
Old   December 22, 2009, 02:39
-mAx-'s Avatar
Maxime Perelli
*create a circle (surface)
*create a diameter (edge)
*split the surface with the edge
*delete the entity you don't want
*sweep surface by selecting your semi-circle, and selecting the vector for the extrusion (you have created a volume)
that's it
Drawing Semi Cylinder sambayo ANSYS Meshing & Geometry 4 July 26, 2014 15:01
[GAMBIT] Import drawing file teguhtf ANSYS Meshing & Geometry 11 October 16, 2013 10:09
What a Strange Drawing in GAMBIT... teguhtf ANSYS Meshing & Geometry 3 October 5, 2009 11:17
who can help me in drawing this mesh-please reply Andrea Cortes FLUENT 6 June 23, 2008 06:13
drawing of contour plots chinthakindi Main CFD Forum 1 April 27, 2004 04:33
