June 24, 2009, 10:06 |
3D elbow
nathalie bardin monnier
hi
I have tried to design a 3D elbow in gambit with instructions found on the site 1 circular face 2 draw an hyperbol starting from the centre of the circular face 3 sweep circular face along the edge but it does not work i have a error message writing that face and edge have common points ... If anyone could help me ! I think i willpost another thread for the meshing ! thanks a lot gambitly yours, nathalie |
June 25, 2009, 01:23 |
Maxime Perelli
Rep Power: 41 |
copy your edge and re-try with the edge you just created with copy (face and edge will be separated)
In memory of my friend Hervé: CFD engineer & freerider |
June 25, 2009, 08:36 |
always problems
thanks max,
I have tried what you wrote. But there are still problems remaining. I have the same error message telling me that the face and edge path are parallel ?? If someone has any idea .. thanks Nathalie |
June 25, 2009, 10:22 |
Maxime Perelli
Rep Power: 41 |
this isn't the same error message.
Now your face and the edge are on same plane? Just copy your edge with translation (give an translation, else both edges will be superposed)
Appropriate model for turbulent, steady state pipe elbow flow | milos | OpenFOAM Running, Solving & CFD | 4 | July 9, 2009 02:24 |
multiphase simulation... 2D flow through an elbow | Tim | CFX | 10 | April 3, 2008 18:13 |
rectangular elbow air duct problem | tony | FLUENT | 2 | August 20, 2006 19:07 |
problem of elbow pressure drop | Tony | FLUENT | 2 | July 17, 2006 17:03 |
Creating inflation layers for elbow with airfoil ! | Aplus | CFX | 1 | March 13, 2006 22:22 |
