[Other] Workbench ANSYS12.0 geometry&mesh
Old   July 15, 2009, 04:58
Arrow Workbench ANSYS12.0 geometry&mesh
lhorion is on a distinguished road
I'm a new user to ansys workbench 12.0. I created a 3D geometry, and i would like to make a 2D geometry out of it.
I used some Slices and Body Op>Delete and Thin (with thickness and face offset set to 0) to get only the face of interest, which lies in the XY plane.
I read in a discussion that the next step is to extrude or revolve my face on a short distance: 1 element.
But I'm facing a problem: I can not make any extrusion or revolve operation when my bodies are 'Surface Bodies'. So i tried to give a small non-zero value to the 'thin' operation, but this does not give the proper result.
Further, when I open the meshing interface, I can not select 'Edit in CFX-Mesh' anymore.
So if someone could help or explain me a smarter way to go to a 2D geometry analysis, starting form a 3D geometry.
Thank you.
lhorion.
lhorion is offline   Reply With Quote
Old   July 16, 2009, 13:43
Default Solver?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
If your solver is Fluent, the 2D cut is fine. Just set the mesher setting to 2D...
If you solver is CFX, then you can extract a sketch and extrude it to get the 2.5D (one cell thick).
Perhaps you could contact tech supp at 1-800-937-3321 to get help with this (I am not as good at DM as I should be yet).
PSYMN is offline   Reply With Quote
2dto3d, ansys12, designmodeler, geometry
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 09:23
Macro command combatibility ANSYS workbench Tassos CFX 6 January 13, 2014 04:19
ICEM CFD in Workbench marek CFX 1 February 15, 2008 10:35
Workbench Transient Omer CFX 0 January 15, 2007 14:21
Bi-directional FSI using Workbench Stuman CFX 0 April 5, 2006 19:31
