[GAMBIT] Kindly asking help about "unfilted mesh" in Gambit |
July 17, 2009, 06:23 |
CJ
Rep Power: 16 |
When I export a mesh file , it warns : At least one geometry entity has no mesh for export . You can use the "Unmeshed" filter in the geometry summarize picker to find the unmeshed entitied.
Then I did use unmeshed picker to check all the volumes, I don't think there is one of them unmeshed. Also it seems ok when i input the mesh in to Fluent. (It runs properly) Is there any one could give me some guide lines? Thanks a lot! C.J |
July 17, 2009, 06:49 |
Maxime Perelli
Rep Power: 41 |
you may apply this filter for volume and also surface.
maybe you defined a standalone surface, which doesn t belong to any volume. That's why you can run your mesh properly.
In memory of my friend Hervé: CFD engineer & freerider |
July 17, 2009, 08:03 |
CJ
Rep Power: 16 |
Thanks MAX. That is probably the problem. I will check it now~
July 17, 2009, 08:04 |
#4 | |
CJ
Rep Power: 16 |
"" Thanks MAX. That is probably the problem. I will check it now~ |
May 19, 2020, 13:00 |
Gambit export error
Surya
I am new to Gambit software. When I am exporting the geometry, I am getting a warning saying as "At least one geometry entity has no mesh for export," but all the parts of my geometry has a meshing.
Can anybody help me out with this Thanks in advance |
Gambit Startup Window | Jay Shim | FLUENT | 2 | February 12, 2015 14:05 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
Gambit batch - kill "Startup" box how? | Chris Bailey | FLUENT | 2 | February 23, 2005 09:05 |
3-D Mesh Check in Gambit..... | SHR | FLUENT | 4 | March 25, 2003 03:10 |
