-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   bounding box in tgrid 3.6.8 (http://www.cfd-online.com/Forums/ansys-meshing/66907-bounding-box-tgrid-3-6-8-a.html)
Anthony July 28, 2009 08:50
Colleagues of mine use tgrid 5.x.x to create a rectangular bounding box around a mesh model (stl model) for the computational domain.
However, I'm stuck with tgrid 3.6.8 :). This version lacks the "bounding-box" command.
Is there a way to do the same thing in tgrid 3.6.8? I can create an stl box in another package. But I wouldn't know how to use this to specify the comp. domain.
Regards,
A.
wadebogs July 28, 2009 14:16
My advice is get TGrid 5! It's sooooo much better than 3.
You just need to bring in a mesh from another package. Nothing special about setting up the computational volume. What are you modelling?
Anthony July 29, 2009 13:32
I know :). But I can't get it. My 'colleagues' are actually people from another company using another license.
I'm modelling the flow across a mesh (stl file) I made in another package. I was instructed by my colleagues how to make a bounding box computational domain in Tgrid 5 (this is basically: read in STL and use 'bounding box' function) . But I can't figure out how to do this in 3.6.8 or any of the packages I found on the net.
wadebogs July 29, 2009 15:05
You can't find anything or don't have anything at your disposal to create a mesh of a box?
:D
GAMBIT? ANSA? ICEM? GRIDGEN? Nothing???
I dunno much about the openfoam meshers but I'm guessing there must be some free software out there which will create and mesh a box for you!! :(
PSYMN July 30, 2009 12:23
Box for free...
Heck, if you give us the Far field mesh size and the corner coordinates, somoene on CFD Online will probably help you out.
I could generate a quick mesh in just a bit more time than it takes me to type this post and then post it in *.msh format.
Most people use the same tunnel for all their models, so you can just put it in a special place and use it when you need it...:cool:
