July 28, 2009, 08:50 |
bounding box in tgrid 3.6.8
Rep Power: 16 |
Colleagues of mine use tgrid 5.x.x to create a rectangular bounding box around a mesh model (stl model) for the computational domain. However, I'm stuck with tgrid 3.6.8 . This version lacks the "bounding-box" command. Is there a way to do the same thing in tgrid 3.6.8? I can create an stl box in another package. But I wouldn't know how to use this to specify the comp. domain. Regards, A. |
July 28, 2009, 14:16 |
Rep Power: 16 |
My advice is get TGrid 5! It's sooooo much better than 3.
You just need to bring in a mesh from another package. Nothing special about setting up the computational volume. What are you modelling? |
July 29, 2009, 13:32 |
Rep Power: 16 |
I know . But I can't get it. My 'colleagues' are actually people from another company using another license.
I'm modelling the flow across a mesh (stl file) I made in another package. I was instructed by my colleagues how to make a bounding box computational domain in Tgrid 5 (this is basically: read in STL and use 'bounding box' function) . But I can't figure out how to do this in 3.6.8 or any of the packages I found on the net. Last edited by Anthony; July 29, 2009 at 13:51. |
July 29, 2009, 15:05 |
Rep Power: 16 |
You can't find anything or don't have anything at your disposal to create a mesh of a box?
GAMBIT? ANSA? ICEM? GRIDGEN? Nothing??? I dunno much about the openfoam meshers but I'm guessing there must be some free software out there which will create and mesh a box for you!! |
July 30, 2009, 12:23 |
Box for free...
Simon Pereira
Rep Power: 47 |
Heck, if you give us the Far field mesh size and the corner coordinates, somoene on CFD Online will probably help you out.
I could generate a quick mesh in just a bit more time than it takes me to type this post and then post it in *.msh format. Most people use the same tunnel for all their models, so you can just put it in a special place and use it when you need it... |
Display Modes | |
[surface handling] Command line tool for finding the bounding box of an STL file | terrybarnaby | OpenFOAM Meshing & Mesh Conversion | 8 | November 4, 2016 13:09 |
SnappyHexMesh plane surface bounding box | podallaire | OpenFOAM Bugs | 22 | August 26, 2009 07:34 |
bounding box in tgrid 3.6 | Anthony | ANSYS | 0 | July 28, 2009 08:43 |
best way to mesh a thin box? | tony | CFX | 1 | January 14, 2008 13:22 |
Immersol Simulation of a Heated Box | Dong | Phoenics | 0 | March 2, 2006 21:20 |
