Home > Forums > ANSYS Meshing & Geometry
Pro E 2 and ANSYS 12??
Old   July 31, 2009, 21:16
Default Pro E 2 and ANSYS 12??
hun
hung is on a distinguished road
Does ProE2 work with ANSYS12?
I got the problem with CAD configuration
when i tried to run Ansys CAD configuration manager
Input Values are...
-UGII_BASE_DIR
-PROELOADPOINT C:\Program Files\proeWildfire 2.0
-PROE_START_CMD C:\Program Files\proeWildfire 2.0\bin\proe1.bat
Unigraphics Config WB --- NO
Unigraphics Config ICEM --- NO
Pro/Engineer Config WB --- NO
Pro/Engineer Config ICEM --- NO
Prerequisites ..... Configure Success
PE WorkBench ..... Not Configured -- Invalid Pro/Engineer Version
I could not import model from proe to ansys.
many thanks
hung
hung is offline   Reply With Quote
Old   August 3, 2009, 01:00
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
export your proE geometry in STEP-file, and import it in Ansys
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 24, 2009, 11:33
SUNSHINE
SUNSHINE is on a distinguished road
Can i do meshing in Pro/mechanical and import directly to ANSYS PRE?
SUNSHINE is offline   Reply With Quote
Old   August 25, 2009, 00:34
-mAx-'s Avatar
Maxime Perelli
I don't think so.
You will have more liberty to mesh your geometry within Ansys rather than in Pro-M
Old   August 25, 2009, 08:36
Default ProE
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Back to your original question...
ANSYS Workbench supports Pro/E all the way thru Wildfire4...
Workbench also supports ANSYS Mechancial APDL (AKA Classic), or you could use the newer ANSYS Mechanical app (AKA ANSYS Simulation) and you can use the new ANSYS Meshing app with either or mesh in Mechanical APDL.
Try out Workbench 12 and see if it meets your needs, it should work with your current licenses.
PSYMN is offline   Reply With Quote
Old   August 8, 2010, 22:37
hun
Thanks anyway, I found out that I should reconfig ProE with Ansys again.
Thread Tools
Trackbacks are On
Command Line Run for ANSYS Liaquat ANSYS 10 July 30, 2016 05:03
how to map resultd from cfx to ansys? ritesh CFX 2 June 1, 2011 07:52
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 04:47
Free UK seminars: ANSYS CFD software Gavin Butcher CFX 0 November 23, 2004 10:13
