Gambit Segmentation Fault
I built a simple mesh in gambit that I need in openFOAM, however, everytime i try to convert i always get this:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : gambitToFoam mesh.neu Date : Aug 18 2009 Time : 09:24:36 Host : bale-login PID : 21117 Case : /nfs/06/astalnak/OpenFOAM/OpenFOAM-1.5.x/tutorials/interFoam/fillWaterNewMesh2 nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Title: mesh Written by Gambit version 2.3.16 File written on 18 Aug 2009 09:12:28 number of points: 21869 number of cells: 21350 number of patches: 0 Reading nodal coordinates Reading cells Reading cell streams Reading cell stream labels Finished reading cell stream labels Reading cell streams Reading cell stream labels Finished reading cell stream labels Finished lexing gambitToFoam: Gambit file format does not provide information about the type of the patch (eg. wall, symmetry plane, cyclic etc). All the patches have been created as type patch. Please reset after mesh conversion as necessary. Default patch type set to empty #0 Foam::error::printStack(Foam::Ostream&) in "/usr/local/OpenFOAM/OpenFOAM-1.5/lib/linux64IccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/usr/local/OpenFOAM/OpenFOAM-1.5/lib/linux64IccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libpthread.so.0" #3 Foam::cellShape::faces() const in "/usr/local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64IccDPOpt/gambitToFoam" #4 _ZN4Foam8polyMeshC9ERKNS_8IOobjectERKNS_5FieldINS_ 6VectorIdEEEERKNS_4ListINS_9cellShapeEEERKNSA_INSA _INS_4faceEEEEERKNSA_INS_4wordEEESN_RKSK_SP_SN_b in "/usr/local/OpenFOAM/OpenFOAM-1.5/lib/linux64IccDPOpt/libOpenFOAM.so" #5 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<Foam::word> const&, Foam::word const&, Foam::word const&, Foam::List<Foam::word> const&, bool) in "/usr/local/OpenFOAM/OpenFOAM-1.5/lib/linux64IccDPOpt/libOpenFOAM.so" #6 main in "/usr/local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64IccDPOpt/gambitToFoam" #7 __libc_start_main in "/lib64/libc.so.6" #8 _start in "/usr/local/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64IccDPOpt/gambitToFoam" Segmentation fault |
In Gambit, select Fluent Solver.
Export your *.msh mesh-file. Then in OpenFOAM, > fluentMeshToFoam your_file.msh ... If you used Hexcore with hanging nodes, then you need to convert your mesh file with tpoly utility from Fluent. Then in OpenFOAM, > fluent3DMeshToFoam your_file.msh |
fluentMeshToFoam is giving me the error -
Problem : cannot find a single face in the mesh which uses vertices 4(61206 61208 61316 61315) From function findFace(const primitiveMesh&, const face&) in file fluentMeshToFoam.L at line 858. So that isn't working either, and the mesh is just a simple cube as well. |
have you boult a 2d, or 3d mesh?
what kind of cells? (hexa, tetra, prism)? have you set the BC? By the way, I see you have linux 64bit: do you have also fluent for linux 64bit? I need the installation file (for using the tpoly utility) |
I actually have linux 64 bit on at a different location I'm running 32 bit on both on this location. And its a 3d mesh with hex cells, what file did you say you needed?
I need the tpoly utility from Fluent 64bit (linux version).
Regarding your mesh, it should work. can you paste the errors from the fluentMeshToFoam. |
i actually have the fluentMeshToFoam in a different string -
http://www.cfd-online.com/Forums/ope...oam-error.html |
Ok I checked the thread.
Can you provide your mesh file? or the dbs file I never had any problem from gambit (windows) into OpenFOAM |
