[TGrid] unable to find periodic twin ??
Old   August 14, 2009, 10:50
Default unable to find periodic twin ??
aeroosso is on a distinguished road
Hi to all,
I am trying to simulate a turbine vane. I have been using Gambit & Fluent for 2 years, using multiblock structured grid. But, nowadays I have to use unstructured grid for the increased complexity in geometry. Tgrid is more powerful than Gambit in creating Boundary Layers. That's why I am trying to generate the mesh in Tgrid. My computational volume consists of turbine blade surfaces (le, ps, ss, te), hub, casing, inlet, outlet and periodic boundaries. I was trying to generate prisms from the hub, casing and blade surfaces using the same growth options. Everything goes well except for the periodic boundaries. It creates the boundary layer faces correctly for one of the periodic boundary, but not for the other shadow part. When the time comes for remeshing the shadow periodic boundary it could not find periodic twin faces for some portion of the boundary layer. Instead for that portion it creates a wall.. It is so weird. Have anyone of you encountered such a problem?
Thank you in advance...
aeroosso is offline   Reply With Quote
Old   September 21, 2009, 18:29
Default Fyi
I figured out that the problem was related to imperfections in the geometry.
Periodic boundary condition Arif FLUENT 3 March 9, 2017 01:18
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Must periodic oscillation give periodic results? zonexo Main CFD Forum 6 May 13, 2007 15:36
Gambit error : Unable to find Exceed X Server Jarod FLUENT 2 November 4, 2004 06:41
