[GAMBIT] How to split a hollow sphere in special different spaces
Like Tree5Likes
  • 1 Post By -mAx-
  • 1 Post By -mAx-
  • 1 Post By -mAx-
  • 1 Post By -mAx-
  • 1 Post By -mAx-
Old   August 16, 2018, 12:11
Default How to split a hollow sphere in special different spaces
Aja
aja1345 is on a distinguished road
I want to create grooves in a hollow sphere (please see this thread). As you know, if I want to create 6 groove in this hollow sphere, first, I should create a volume as a groove, secondly I should create 5 copy of this volume of groove via rotation of angle 60 deg (360/6=60 deg) and then, I should split volume of hollow sphere with volumes of these grooves (6 volumes). This process is OK and I have not problem.
But If I want to design thing like to the following picture, How can I design this case in Gambit? In fact, I want to in 0.3 radian (see the picture), distances of C_1 and C_2 apply so that ratio of C_2/C_1 is equal to 3.5 and then I split volume of hollow sphere with volumes of the grooves.
I am grateful that guide me in this case.
Thanks.
aja1345 is offline   Reply With Quote
Old   August 17, 2018, 01:02
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
This time I don't get your point
aja1345 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 17, 2018, 04:13
Aja
Thanks your reply
Which part of the text you have problem? Please tell me so I may be able to clarify it for you.
Old   August 17, 2018, 04:37
-mAx-'s Avatar
Maxime Perelli
Every thing
I don't understand what you want to do (in comparison with the other thread)
aja1345 likes this.
Old   August 17, 2018, 07:18
Aja
Every thing
Thanks. I try to clarify it for you. My English language is not very good. for this reason, excuse me.
In fact, I want to create ratio of C_2/C_1=3.5 in my design.
C_1= width of groove
C_2=width between two groove
According to the before picture,this design ratio (C_2/C_1) should create in a face that have angle of 17.19 deg with respect to equator. The volumes of groove should be placed on the sphere such that the mentioned value of design ratio (C_2/C_1=3.5) has been set for grooves. then, we can split volume of hollow sphere by volumes of the grooves.
Of course, I forgot say something to you. Angle of groove with respect to equator is equal to 30 deg, as shown in the following picture. This seems to be possible to design it in design but in case ratio of C_2/C_1, I have not any idea.
Old   August 17, 2018, 08:07
-mAx-'s Avatar
Maxime Perelli
It is always the same: create basic geometry, then rotate and translate.
For instance, you can start by creating a surface with desired dimensions (inc. C1).
The rectangle should be centered on the center of the sphere (also Origin from coordinate system)
Then rotate the rectangle.
Next Step, is a translation,and finally another rotation
aja1345 likes this.
Old   August 17, 2018, 08:22
Aja
Attachment 65134
Thanks.
Yes you are right. Note that number of groove is 6. In this condition, how can I apply the dimension of C_2 in my design? I don't understand this case in your guidance.
Old   August 17, 2018, 08:53
-mAx-'s Avatar
Maxime Perelli
your C2 will be used as translation from the yellow surface (with help from some trigo)
aja1345 likes this.
Old   August 17, 2018, 09:28
Aja
This is difficult to understand your statement
Old   August 17, 2018, 09:45
-mAx-'s Avatar
Maxime Perelli
Like that
aja1345 likes this.
Old   August 17, 2018, 15:44
Aja
Thanks.
How can I create 5 copy of this configuration(applying C_2.cos(17.19)) in the following panel of gambit?
Old   August 20, 2018, 00:45
-mAx-'s Avatar
Maxime Perelli
with the option "translate"
[Other] 2D adaptive Mesh Refinement baco OpenFOAM Community Contributions 80 August 14, 2022 14:18
[GAMBIT] How to split a hollow sphere in different angles aja1345 ANSYS Meshing & Geometry 2 August 16, 2018 10:53
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
Hollow sphere iside ANSYS Meshing & Geometry 2 July 26, 2011 10:19
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
