Bug in Meshing Parameters menu Spacing1 (1e+10)
There is a Bug in Meshing Parameters input box. Suddenly the Spacing1, Spacing2, and Max Space goes to 1e+10. Even If you correct this, it get updated from somewhere. Because of this size and spacing, ICEM throws lots of errors during Pre-Mesh (shown below). and the problem start getting aggravate during saving in different format. Also Update All does not work properly If anyone came across this problem and found out the way out of it, please share with me. OR is this bug got fixed in new version, please let me know Waiting for your Valuable comments and suggestions. Thanks in Advance. Regards ************************* You may continue to work but if problems arise they may be related to this error. Try using the check/fix function to fix the problem The following message was designed to aid developers fix the problem: error meshing edge 1553 226 ************************** |
I have not seen this, but if you can share the files or screen shots or something, perhaps we can help you sort it out...
If you have access to techsupp@ANSYS.com, please just send it there. Otherwise, perhaps we can deal with it thru CFD Online. Simon |
