[Other] positioning points inside a triangle
Old   September 27, 2009, 14:30
Default positioning points inside a triangle
Rafael Adamy
fael097 is on a distinguished road
hello people, i'm a 3d modeler and animator, and i have a question regarding triangles.
this is a polyomavirus,
it has a icosahedral geometry and 72 capsomeres (the flower things) arranged on its triangles, like this picture:
if i pick a triangle, i can see that it has one capsomere in each vertex and three arranged inside the polygon. my question is how to properly arrange these 3 capsomeres in each triangle. if you take a closer look at the picture, you'll notice that each vertex' capsomere has 5 others capsomeres around it, and the other capsomeres (those arranged inside the triangles) have 6 others. they have to be distanced equally from all the capsomeres surrounding them.
capsomeres are positioned closer to one end of the edge than the other, but it's a question of rotation, not mirroring. the structure is a perfect icosahedron, and the three dimensional structure doesnt matter, it's all about the triangle
thank you in advance!
fael097 is offline   Reply With Quote
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Modelling the Heat flow inside the curing oven Marios Vlad CFX 1 February 6, 2008 07:11
extreme points problem Lipo Wang Main CFD Forum 2 August 18, 2004 03:15
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
