What a Strange Drawing in GAMBIT...
Old   October 1, 2009, 20:09
Default What a Strange Drawing in GAMBIT...
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Dear Friends!!!
I'm Drawing an Airfoil. I use GAMBIT 2.3.30. I take every point of the airfoil >> Import by "ICEM Input" >> Vertex Plot Format >> i use combination of NURBS, Straight, Conic to draw airfoil. The result is good. But After I save and then open it again. The drawing became strange.
I've repeated my steps more than one time. but it's useless.
What's wrong with my step??
Could you help me, please??
Thanks
teguhtf
PS. I've attached my drawing result.
AFTER = After I open and close
BEFORE = Before I open and close
VERTEX PLOT = After I import point by using ICEM Input
teguhtf is offline   Reply With Quote
Old   October 2, 2009, 05:22
Karatix
Karatix is on a distinguished road
have you checked out the website:
http://courses.cit.cornell.edu/fluent/airfoil/step1.htm
That is very helpful for importing airfoils.
Just make sure your file with the points is saved as a .dat file (can be done using editor and saving in the name box as:
Naca4412.dat ). Also make sure you have the same number of points for the top and bottom side, so you can plot both curves (tick plot curves, before you click import).
Hope that helped
Karatix
Karatix is offline   Reply With Quote
Old   October 2, 2009, 06:04
Talking separate it become some part
teguhtf's Avatar
teguh hady
Originally Posted by Karatix View Post
Hope that helped
Karatix
Thanks for your help Karatix
My problem has been solved!!
The solution is the line must not be merged as one line. but keep it become more than one line. The shape of the line will be the same when we open and close file or just scale it.
Old   October 5, 2009, 11:17
Default Thanks.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
A perfect example of what CFD-Online should be...
Thanks Karatix...
PSYMN is offline   Reply With Quote
conic, gambit, icem input, nurbs, strange
sofc geometry drawing with gambit. shunjie FLUENT 1 January 28, 2018 13:32
how drawing using gambit zidane FLUENT 0 March 8, 2009 05:31
Problem of import solidwork drawing into gambit V.L. Koh FLUENT 4 February 27, 2009 09:01
Gambit drawing Peggy FLUENT 3 March 29, 2007 08:41
3D geometry drawing in gambit pmali FLUENT 2 July 26, 2004 08:30
