ACIS error 50004
Old   October 5, 2009, 13:02
Default ACIS error 50004
ali
alinik is on a distinguished road
hi, when I try to import a geometry of STEP format into gambit, I encounter this error :"ACIS error 50004 : coedge parameter rang is zero".
can anybody please help me?
alinik is offline   Reply With Quote
Old   October 6, 2009, 01:46
-mAx-'s Avatar
Maxime Perelli
disable all the options except "make Tolerant"
Else try to reimport your step file into the cad soft you tried to export from.
If it not successfull then, it lies in your first export.
Old   October 6, 2009, 04:17
ali
I almost did what u said but the problem exists.I think if I decrease the tolerance in gambut the problem will be solved
do u have any idea how i can do that?
Old   October 6, 2009, 05:52
-mAx-'s Avatar
Maxime Perelli
on which cad soft do you export your step?
Old   October 6, 2009, 10:58
ali
I used CATIA V5R17 to make the step file
Old   October 6, 2009, 11:27
-mAx-'s Avatar
Maxime Perelli
upload your step file on a server and give the link
Were you able to retrieve your geometry as you imported your step file into CATIA?
Old   October 7, 2009, 00:51
ali
here is the link
http://rapidshare.com/files/28968496..._5004.rar.html
yes I could retrieve my file back in CATIA
Old   October 7, 2009, 10:57
Default Version...
PSYMN's Avatar
Simon Pereira
I have not looked at your file, but it may be a version thing...
CatiaV5 may be exporting an ACIS version that GAMBIT's ACIS reader was never updated to support.
You may want to look into your CatiaV5 export settings to see if it can export in older versions of ACIS. For instance, if it is currently at ACIS 18, then you may want to export as ACIS 12.
Simon
Old   October 8, 2009, 02:13
-mAx-'s Avatar
Maxime Perelli
I was able to import it without problem within gambit 2.4.6
acis error 30001 umesh FLUENT 0 February 12, 2009 04:51
ACIS error 30001: Sanjay Jain FLUENT 0 April 8, 2008 06:20
ACIS erro 50005 rahul FLUENT 0 July 5, 2006 15:57
acis import to cfx-build strudl CFX 1 July 25, 2003 15:44
Importing Acis file to gambit Habib FLUENT 5 June 25, 2001 05:19
