October 13, 2009, 05:47 |
Import a .iges file
Tuffy
Rep Power: 16 |
Hi everyone!
I must import a .iges file in my geometry, it is a real geometry of a vessel that i must include in my project. The problem is that when i import the file I have only the vessel's surface, composed by small faces. Do you know if and how it is possible to create a volume with this import-file? Thanks for your help! Ema |
October 13, 2009, 06:03 |
Maxime Perelli
Rep Power: 41 |
are you using gambit?
can you go back to your cad soft and trying to manipulate data or not? I have few experience with iges, but more with step file. With step can you either import volume or surface. anyway, if you only have this iges file, sure you can create a volume with the surfaces. The surfaces have to be connected (I assume you will have to use the cleaning tool), and your volume has to be closed. If you don't have gambit, forget what I wrote........
In memory of my friend Hervé: CFD engineer & freerider |
October 13, 2009, 06:11 |
Tuffy
Rep Power: 16 |
i have only the iges file.
you've said that surfaces must be connected, do you know how? Thank you!!! |
October 13, 2009, 06:44 |
Maxime Perelli
Rep Power: 41 |
Geometry/Surfaces/Connect
Select All and apply. I would recommand you to take a look at tutorial "Sedan Geometry - Virtual Cleanup"
October 13, 2009, 09:46 |
Tuffy
Rep Power: 16 |
which version of ANSYS are you using?
October 13, 2009, 10:20 |
Maxime Perelli
Rep Power: 41 |
euh... I asked you if you were using Gambit.
I don't have Ansys...
October 14, 2009, 13:54 |
Sew
Simon Pereira
Rep Power: 47 |
If you mean you are using DesignModeler (please be clear about your tools) then you are looking for the "sew" operation. Do a quick help search for "sew" to get the details.
Simon |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
import autocad file | ritmat | FLUENT | 5 | June 1, 2007 12:19 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
Import data from another .cas file of fluent | Umesh | FLUENT | 1 | August 17, 2003 04:51 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
