October 13, 2009, 06:16 |
[ICEM] Bunching nodes along a curve
Stuart
Rep Power: 25 |
In the Curve Mesh Setup I have been trying different Bunching Laws and values in the Spacing and Ratio boxes to try and get nodes to bunch together at the centre of a curve. But all my attempts result in node bunching at the curve ends. For example: curve with 100 nodes, Bunching law = BiGeometric, Spacing 1 = Spacing 2 = 0.001 and Ratio 1 = Ratio 2 = 2 gives bunching at the curve ends. So I changed the Ratio 1,2 = 0.5 thinking that would reverse the bunching direction but I it didn't. So how can this be done? Thanks. |
October 14, 2009, 14:51 |
Bieponential
Simon Pereira
Rep Power: 47 |
I just tried it and see what you mean about the BiGeometric not working in that way... It seems like it just goes to uniform if you try it...
But the Biexponetial, Hyperbolic and Poisson each worked for me. In my case, I had a curve about 100 units long with size 5 uniform, I set the spacing 1 and 2 to 20 and the ratio 1 and 2 to 0.5... It clearly biased toward the middle at a rate of 2 to 1... I should note that I rarely use this method... If I am going to play with things like this, I would rather use the 2D hexa blocking stuff and just have unstructured patches. |
October 14, 2009, 16:55 |
Stuart
Rep Power: 25 |
Thanks again, I'll give that a try when I get back to my CFD PC.
Trying the appropriate bunching methods seems a bit hit-an-miss at the moment. Can the equations be given to maybe get a better understanding and see what parameters are used for each method? For example, in one instance I have a curve and I'd like the extreme lefthand and righthand elements to be particular sizes but not sure what method or values of ratio(s) etc needed, without trial-and-error. Although you'd rather use the Hexa blocking, spare a thought for us poor souls who only have tetra/prism . |
October 14, 2009, 16:58 |
Ryne Whitehill
Rep Power: 18 |
I was having the same issue, ICEM seemed to always force the RATIO=2 on me.
I ended up using biexponential to distribute my nodes As to the equations, see the help guide. It has all the equations in it |
Display Modes | |
[ICEM] Smoothing a curve | lost.identity | ANSYS Meshing & Geometry | 6 | July 13, 2009 06:23 |
Interpolation (Number of mapped nodes) | Sam | CFX | 3 | January 6, 2008 20:51 |
How to maintain spacing along a new curve? | KB | Main CFD Forum | 2 | June 5, 2007 17:45 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
