Home > Forums > Ansys Meshing & Geometry
Import a .iges file
Old   October 13, 2009, 06:47
Unhappy Import a .iges file
Ema
Tuffy
Ema is on a distinguished road
Hi everyone!
I must import a .iges file in my geometry, it is a real geometry of a vessel that i must include in my project.
The problem is that when i import the file I have only the vessel's surface, composed by small faces.
Do you know if and how it is possible to create a volume with this import-file?
Thanks for your help!
Ema
Ema is offline   Reply With Quote
Old   October 13, 2009, 07:03
-mAx-'s Avatar
-mAx- will become famous soon enough
are you using gambit?
can you go back to your cad soft and trying to manipulate data or not?
I have few experience with iges, but more with step file.
With step can you either import volume or surface.
anyway, if you only have this iges file, sure you can create a volume with the surfaces.
The surfaces have to be connected (I assume you will have to use the cleaning tool), and your volume has to be closed.
If you don't have gambit, forget what I wrote........
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 13, 2009, 07:11
Ema
Tuffy
i have only the iges file.
you've said that surfaces must be connected, do you know how?
Thank you!!!
Old   October 13, 2009, 07:44
-mAx-'s Avatar
Geometry/Surfaces/Connect
Select All and apply.
I would recommand you to take a look at tutorial "Sedan Geometry - Virtual Cleanup"
Old   October 13, 2009, 10:46
Ema
Tuffy
which version of ANSYS are you using?
Old   October 13, 2009, 11:20
-mAx-'s Avatar
euh... I asked you if you were using Gambit.
I don't have Ansys...
Old   October 14, 2009, 14:54
Default Sew
PSYMN's Avatar
Simon Pereira
PSYMN will become famous soon enough
If you mean you are using DesignModeler (please be clear about your tools) then you are looking for the "sew" operation. Do a quick help search for "sew" to get the details.
Simon
PSYMN is offline   Reply With Quote
Thread Tools
Trackbacks are On
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
import autocad file ritmat FLUENT 5 June 1, 2007 13:19
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
Import data from another .cas file of fluent Umesh FLUENT 1 August 17, 2003 05:51
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
