[GAMBIT] Install Gambit in Win Vista Ultimate
Old   October 15, 2009, 01:09
Default Install Gambit in Win Vista Ultimate
Hector Antonio Alcalde Ludeņa
hector is on a distinguished road
Hi
I buy a Laptop with operative system: Windows Vista Ultimate 64 bits, but when I install my exceed and my gambit appears a message, this message says:
Gambit build SP2006032921.
Warning : The current transport does not permit the attempted TCPIP connection.
TRANS(SocketINETGetAddr): tnamebysocket() failed
TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed
TRANS(Open): transport open failed for tcp/familiaalcalde:0
Unable to open display
Could you help me with that?
Thanks!
hector is offline   Reply With Quote
Old   October 15, 2009, 09:09
Anastasios
kovamaniac is on a distinguished road
Which Exceed version did you use?
kovamaniac is offline   Reply With Quote
Old   October 15, 2009, 09:40
Hi
My Exceed version is: Exceed Hummingbird 2008
Regards
Old   October 15, 2009, 12:11
Anastasios
The Exceed version is proper. I also use it on Vista x64 Ultimate.
Try installing Gambit again, removing all the security limitations from firewall
Old   October 16, 2009, 01:08
My friend
I remove all the security limitations from my fire wall, but the Gambit doesn't run
This message appear (I think that is other)
Locating Exceed installation ...
gambit failed in locating Exceed installation on your system.
Please try to start Exceed manually before you run gambit.
Starting C:\Fluent.Inc\gambit2.3.16\ntx86\gambit.exe -device open -id default_id400 -new ...
Please try to help me with that
Old   October 16, 2009, 15:35
Default 64 of one, 32 of the other?
PSYMN's Avatar
Simon Pereira
I thought Gambit only supported Linux 64, not Windows 64? Are you running it as a 32 bit application?
Old   October 17, 2009, 01:34
Hi
Well actually I try tu run Gambit and Exceed in 64 bit application, I have a friend who have Gambit in 64 bit application and it run perfectly.
Please try to help me with that guys...
64 bits, gambit, vista
Gambit on Opensuse install error Thiago FLUENT 7 December 14, 2013 07:59
tips for runing Gambit without Exceed in Win Vista Fabio Saltara FLUENT 9 September 23, 2011 13:59
GAMBIT display pro, under VISTA aldon ANSYS Meshing & Geometry 8 September 11, 2011 11:14
[GAMBIT] Gambit start win vista? ferranpm ANSYS Meshing & Geometry 1 June 8, 2009 16:23
Fluent / Gambit on VISTA or XP ??? Ralf Schmidt FLUENT 2 February 25, 2009 21:35
