-   ANSYS Meshing & Geometry (
-   -   How to reduce skewness in GAMBIT? (
lyzheng87 October 17, 2009 03:57
Can i know how to reduce the skewness in GAMBIT?
-mAx- October 19, 2009 01:48
by knowing the reason of skewed elements....
and then correct the parameters or topology
ArmanCFD April 23, 2016 08:36
Hi. I generate tet mesh with size function to create a mesh with more density on the solid-fluid interface. My mesh has 143 elements (0.02%) that are silver and their skewness is in the range of 0.95-1.
Is this skewness leads my results into inaccurate solution or it's OK?
If so, How can I reduce the skewness?
I'll be thankful for any advice.
-mAx- April 25, 2016 02:16
check where are those cells localized.
If they are in the same area, then for sure you can fix the problem with some mesh settings
