Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] geometry
Old   October 22, 2009, 06:16
Default geometry
bob12 is on a distinguished road
hi all
if i modelling a tube where into have a flow, the lateral surface is one or two?
i suppose that is one connect surface.
also i have split a volume, tha are connect(the volume), with a surface and generated two volume real connected. but gambit give me a warn: the connected geometry may be imprinted by the request operation.
What do it mean?
thank you all for the attention, i'm not doing without us!!
bob12 is offline   Reply With Quote
Old   October 22, 2009, 08:05
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Originally Posted by bob12 View Post
hi all
if i modelling a tube where into have a flow, the lateral surface is one or two?i suppose that is one connect surface.
I don't understand what you are trying to explain
What do it mean?
Is your operation successfull? if yes, forget the warning
If not, check if the surface splits all the volume
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 22, 2009, 08:45
sorry for my english but it's bad...
however in a pipe i create two volume one for solid and one for liquid, so the querry is: how many surface can i do in the interface?
i hope that now is clear..
thank you vary much
Old   October 22, 2009, 08:54
-mAx-'s Avatar
Maxime Perelli
You shouldn't model and mesh the solid region (except in special cas like thermal conduction, etc....)
Else you don't have to take care of your "interfaces" (which are not interface --> cf sliding mesh)
Indeed once you export your mesh, gambit takes all the surfaces which are not defined as specific BC, and defines them as wall
Basically if you mesh a cylinder (3 surfaces: top + bottom + lateral), you define the top and bottom as inlet/outlet, you export the mesh , and you get 4 BC: inlet/outlet and the rest (lateral) as wall.
Did I reply your query?
Old   October 22, 2009, 10:03
i don't understand this:
  • cf sliding mesh
suppose that are important model the solid, the surface lateral is one or two?
Old   October 22, 2009, 10:16
-mAx-'s Avatar
Maxime Perelli
*for sliding mesh, you need to have Boundary Conditions called interface (but it has nothing to do with what you mean)
*hmmm, we are not understanding us together.
Lets take a cylinder, in the middle you have a marble.
So the flow will flows in the cylinder, but not in the marble (just around)
So you need to substract the marble from the cylinder (boolean operation).
You get ONE volume, but with a hole in the middle (marble substracted).
So the hole represents the solid, but it is not mesh/modelised...
At the "interface" between the flow and the marble there is only one surface representing the outer surface from the marble (will be set as wall in the BC panel).
hope it helps (i can also german and french if it helps)
Old   October 22, 2009, 10:31
thank so much
sorry if i didn't expleined well, and it's better in english
Thread Tools
Trackbacks are On
Importing CAD geometry and Editing edges to match Ahmed CFX 14 June 26, 2015 12:16
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 12 August 17, 2011 21:28
SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Mesh Utilities 17 June 15, 2010 19:51
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
