Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] Help with 2-D surface element sizing
Old   October 30, 2009, 05:05
Default [GAMBIT] Help with 2-D surface element sizing
siw
Stuart
siw is on a distinguished road
I'm making a 2-D, hybrid mesh in Gambit version 2.4.6 for an external aerodynamics simulation.
I have assigned node sizings on all the edges (the farfield edges have large element sizes and the aerodynamic body has small element sizes and also includes the boundary layer mesh).
When I mesh the fluid domain Gambit uses the edges nodes but makes the elements even smaller away from the edges (see wall mesh.jpg) so that there is not a very nice transition from large farfield elements to small aerofoil elements. And the element quanitity is too high (see mesh.jpg).
So is there an away of setting a global surface element size? Much like can be set in ICEM Tetra/Prism Surface Mesh Setup > Maximum size?
Thanks
siw is offline   Reply With Quote
Old   November 3, 2009, 01:30
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Have you set any size functions?
if the edges of your airfoil are already meshed (node distribution), I yould create a size function (Meshed) with edge as source
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 3, 2009, 02:26
siw
Stuart
There are no size functions in this mesh.
Old   November 3, 2009, 03:22
-mAx-'s Avatar
Maxime Perelli
then use Size Functions
Thread Tools
Trackbacks are On
boundaries with gmshToFoam‏ ouafa Open Source Meshers: Gmsh, Netgen, CGNS, ... 7 May 21, 2010 12:43
[ICEM] Element sizing question siw ANSYS Meshing & Geometry 3 July 27, 2009 08:44
Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan Open Source Meshers: Gmsh, Netgen, CGNS, ... 0 June 29, 2009 00:48
Problem with Gmsh nishant_hull Open Source Meshers: Gmsh, Netgen, CGNS, ... 17 December 7, 2007 01:33
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
