-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   Drawing Semi Cylinder (http://www.cfd-online.com/Forums/ansys-meshing/69747-drawing-semi-cylinder.html)
sambayo November 3, 2009 03:32
since i am not very familiar with gambit i have a question that is very easy i think but i cant do it
how to draw a semi cylinder in Gambit ?
Thank you
-mAx- November 3, 2009 06:18
different ways:
* create an arc-circle with 180
* create a full-circle and create and straight edge --> split cercle with edge
sambayo November 3, 2009 08:11
thank you but then how should i extrude it to make it 3d Cyliner (pipeline)
-mAx- November 3, 2009 09:41
once you have your semi-circle, close it with a straight edge.
Create the surface and then create volume (sweep faces)
forough July 26, 2014 15:01
Draw semi Cylindrical wire
how to draw and mash a semi cylinder and canal in Gambit?
