highly skewed elements in grid
Old   November 30, 2009, 14:56
Default highly skewed elements in grid
ryan robinson
ryan is on a distinguished road
I was trying to mesh a face with around a 2d airfoil.But after meshing the face it shows that i have 18 highly skewed elements.How do i remove them.
ryan is offline   Reply With Quote
Old   December 1, 2009, 23:18
Dr Suvash C Saha
Suvash Saha is on a distinguished road
I am also facing the same problem. Anybody here to help?
Suvash Saha is offline   Reply With Quote
Old   December 2, 2009, 01:24
Dr Suvash C Saha
I have found a way. However, I don't know whether it is right way or not! Just go to Grid->Polyhedra->Convert Skewed Cells. I found it in the UG of fluent.
Old   December 2, 2009, 02:41
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
there is always a reason for skewed cells.
Try to found this reason (small edge, small angle etc...)
If you don't see any geometrical reason, then try to "play" with mesh parameters (size function etc....)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Can highly skewed elements create problem?? Sanjay Jain FLUENT 1 April 8, 2008 15:57
help: the volume mesh has highly skewed elements xiaofish FLUENT 3 September 18, 2007 09:51
what to do w/ highly skewed elements? (GAMBIT) mike FLUENT 5 June 2, 2007 22:10
Highly skewed elements Hengky FLUENT 2 August 11, 2005 12:17
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
