November 21, 2009, 07:16 |
Different Types of meshing
Hey,
I have a question about using different sorts of meshes in Gambit. I want to split up a face in 4 different faces. In 2 faces i want to use a Tri - Pave mesh and in the 2 others a Quad - Map mesh. In front and aft of the 'boat' i should use a Quad - map mesh for a good resolution of the free water surface. All the rest doenst really matter so i use a tri mesh. The boat is substracted from the Flow Volume and the meshing is ok. But when i export te mesh, Gambit makes a (default) wall BC of the edges 1-4 (colored in red) So what should i do so i can split up the face for an optimal meshing but without this wall BC? any help is appreciated!! Vincent |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 05:01 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
Is conformal meshing really an advantage? | Alvin Szeto | Main CFD Forum | 19 | June 27, 2003 07:23 |
