December 10, 2009, 06:24 |
Blocking with periodicity
JSM
Rep Power: 20 |
I tried to block the simple geometry with periodicity. I defined periodicity for outer four vertices (shown in third figure). I don't know where I made mistake. I could not mesh with periodicity. could anybody give me suggestions?
With regards, JSM |
December 11, 2009, 14:29 |
Periodic faces...
Simon Pereira
Rep Power: 47 |
From your third image, I can see that you have not made the faces periodic (by selecting all the verts)... To make the faces periodic, you need to make all 4 pairs of verts attached to that face periodic. You can check this by turning on the faces with the periodic function, then you will see red rectangles to mark the periodic faces.
To make the axis periodic, you will need to click those verts twice to mark them as the periodic pair of themselves. Once you have all the 4 verticies of a face periodic, the face will be periodic and all future splits across that face will already be periodic. |
December 13, 2009, 22:45 |
JSM
Rep Power: 20 |
Hi Simon,
Thanks for your help. I will follow your suggestions and come back to you if I face any difficulty. Once again thanks
With regards, JSM |
December 14, 2009, 01:46 |
JSM
Rep Power: 20 |
Hi Simon,
Thanks for help. I could able to block this geometry Once again thanks a lot.....
With regards, JSM |
Translational Periodicity / Velocity Profile | sberez | CFX | 1 | November 15, 2009 17:29 |
Mesh is created in blocking | Severin | CFX | 3 | September 18, 2007 09:02 |
Periodicity in CFX | Sam S | CFX | 2 | August 27, 2007 00:59 |
Problems with periodicity (ProE-ICEM) | Danny | CFX | 3 | December 11, 2006 09:13 |
translational periodicity | wasim | CFX | 0 | May 13, 2006 13:34 |
