Home > Forums > ANSYS Meshing & Geometry
3D volume meshing of pipe
Old   December 3, 2009, 17:44
Default 3D volume meshing of pipe
elsikre
srosendal is on a distinguished road
Hi
I want to make a volume mesh in WB12 and I am having trouble making the it fit the whole pipe. After dividing it into half, I made a fill, which can be seen on the picture and it works ok but because this igs file is not only round, I need a better tool. Right now I am trying to make an enclosure using the user defined body but just can't get it right.
Can someone help ? thx
srosendal is offline   Reply With Quote
Old   April 21, 2010, 16:41
Default Shouldn't be a problem...
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You should use the option that just expects you to select the curves at the pipes openings and then does the rest its self... It works for any shape piping assembly... If this is still a problem, let us know and we can get you going again (I know it was an old post and you may have figured it out)
PSYMN is offline   Reply With Quote
Old   April 23, 2010, 10:26
Default thx
elsikre
I figured it out eventually
Thanks a lot though
Thread Tools
Trackbacks are On
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
