Home > Forums > ANSYS Meshing & Geometry
[ICEM] [FLUENT]How to provide boundary conditions
Like Tree2Likes
  • 1 Post By thinktank
  • 1 Post By PSYMN
Old   December 5, 2009, 15:31
Default [FLUENT]How to provide boundary conditions
thinktank is on a distinguished road
I have a complex 3d geometry that I have to mesh and study the flow in. To start off, I am just trying to simulate poisuelle flow through a parallel plate channel. To start off, I made a cuboid in 3d in Soldworks, saved a drawing file as .dwg, and then imported it in ICEM. Then I converted the curves to a surface, and then used mesh type "quad" and mesh method "autoblock" to mesh the surface.
The mesh worked fine, and I was able to import the mesh to FLUENT. However when I imported the geometry from SOLIDWORKS I just got 4 curves and since these curves didnt have specific "parts" assigned to them, they didnt show up as separate entities in ICEM CFD as I would have liked it to be.
So my question is: how do I assign boundary conditions to a curve, which is not labelled as a separate part?
I have attached the .prj file as well as the mesh file for FLUENT below. It would be great if somebody could point out how the boundary conditions are assigned after importing a geometry from a CAD program, since I couldnt find anything on it in the documentation.
amin_gls likes this.
thinktank is offline   Reply With Quote
Old   December 6, 2009, 09:58
Default All wrong?
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
I don't get why you are creating surfaces or importing geometry into Fluent...
Try some of the ICEM CFD Tutortials as a first go thru.
Your steps should have been more like...
1) create the solid 3D geometry in Solidworks and output as a dwg or acis or something like that. (ACIS is the best of the neutral formats)
2) Read the model into ICEM CFD. You should ALREADY have curves and surfaces and points... If you just have surfaces, run "Geometry (tab) => Build Diagnostic topology to build the rest." If you just have curves, you probably did something wrong in Solidworks.
3) Break up the model into parts such as Inlet, outlet, symmetry plane, etc. When the mesh is generated, the surface mesh (volume boundaries) will be in these parts and you will easily apply bocos in Fluent.
4) Set sizes and other meshing params with the mesh tab.
5) Mesh... You need a volume mesh for 3D Fluent. A quad mesh with the auto blocker is just a surface mesh and not at all appropriate for 3D Fluent (But great for structural explicit with LSDyna or something like that). Again, I will point you to the tutorials. You could make a nice Hexa mesh or a Tetra/Prism mesh.
6) Setup boco types (optional) and output mesh to Fluent...
7) Read mesh into Fluent and finish setting up, then run.
lth likes this.
PSYMN is offline   Reply With Quote
Old   December 10, 2009, 20:26
Hey Simon..thanks for your help...I didnt mean to import the geometry...i just meant importing the mesh...however thanks for your explanation. I will be a lot of help when I start the 3d modelling.
Thread Tools
Trackbacks are On
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
Problems with boundary conditions for a lowRekOmegaSST turbulence model cfdmarkus OpenFOAM Running, Solving & CFD 16 November 14, 2011 05:44
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
