Prism layers around interior wall
2 Attachment(s)
Im having some issues with prism layers around interior walls:
1) at some places, the number of layers seems to decrease and then increase back to my specified amount. Any idea why this could be happening? 2) At the end of the interior wall, the prisms seem to taper off to nothing. I have seen other results where this is done properly, but can't seem to mimic it. I have tried lowering my minimum quality to 1e-6 which fixed some areas, but not all. I get the following message when generating my prism using the batch utility: max_prism_angle reset to 179.943 because the min_prism_quality is 1e-006 Do I need to set the min quality even lower, or is there some other root problem? |
keep the maximum angle 180 degs, and set advanced prism parameters: deselect stairstep
Will try deselecting the stair step option. Thanks, Ryne edit: Your suggestion of disabling stair step did indeed fix problem 1. Still am having troubles with problem 2. |
Baffles...
2 Attachment(s)
If it is a zero thickness baffle, then the stair step is helping you out with quality. In 12.1, you can turn the stair stepping off for baffles, but a better method would be to extrude the end of the baffle further out and call the new surface (interior). Then the baffle will have full prisms and the stair stepping can happen on the interior surface.
I will attach some pics. Simon |
Simon: In response to your suggestion, the shell geometry that I am trying to generate a prism layer around is too complex to extrude further unfortunately. I am trying to recreate someone's mesh of the same geometry, but my prism layers around the end of these shell elements is coming out quite different. Theirs appears not to use stepping, but rather to just convergence the prisms to a point at the end. I tried to turn stepping off to recreate this, but did not get the same results. Is there another setting that might control this end convergence? Thanks, Ryne |
Version?
Were you using 12.1? This doesn't work in 12.0.
Ahh, great :( IT already hates me! Now I'll have to pressure more for them to install 12.1 ASAP. Hopefully 12.1 will kill two birds with one stone and fix my workbench issues as well. Thanks, Ryne |
Send the guys (or dolls) in IT some donuts. :D
2 Attachment(s)
Simon:
Just to clarify, I made a few pictures of what I would ideally like, and what I have seen (refereed to below as "Acceptable") that I cannot recreate. Is there a way to mimic these pictures? All my attempts end with a very weird ending for the prism, sometimes with the prism layers converging to a point OFF of the shell element. Thanks again, Ryne Edit: I think I have achieved the "acceptable" one by doing a single prism layer and splitting it into my number of layers. |
Sure you can, with 12.1.
Sure, see my galleon pics higher up in this thread. With 12.1 and stair stepping off, your prisms will go to the end of the baffle.
By default, it will then create a bunch of pyramids all terminating along a line. If you don't like that, just delete all the tetras and pyramids in the model (keep the prisms, Hexas and shells) and then generate bottom up tetra (delaunay TGlib with the AF option). This will recreate the rest of the volume and build individual pyramids on the side of each prism. (Alternatively, you could select all the pyramids with a subset and then add attached tetras to them (using the subset modify controls), then delete just the elements in the subset and remesh using the fill holes option. This will be quicker and won't require remeshing the whole model. ) A word of warning here, a very thin prism has a high side aspect ratio and will produce a low quality pyramid. That is just reality. On the other hand, your solver might not mind. Simon |
Hi Simon,
I have one question in your last reply. Kindly clarify this. From your reply, I understood that we can delete the pyramids and tetra elements without deleting shells and prisms. I checked the deleting elements option by element type in edit mesh tab. I could not find it. If all volume elements (prism, pyramids and tetra) are in single part name, then how to do this? Thanks in advance. |
1 Attachment(s)
My original issue (number 1) is reoccurring in a stronger fashion. The prism just drops randomly along the interior wall and then picks back up. I have tried turning stair stepping off, but the same thing happens.
Any ideas? (sorry for bad pic quality, can't get it under file size as a PNG) |
How did you do that?
I don't think I could make ICEM CFD do that on purpose...
Why is prism growing in the one direction but no the other? Perhaps this is something I could solve if I had the model in front of me, but I am not understanding how you arrived at this point. Simon |
1 Attachment(s)
Glad it is causing confusing for more people than just me for once :D It was generated as 1 layer and then cut into 17 or so, but this occurs if I generate 17 initially too. It always happens in the same spot, on both sides (somewhat symmetric through the centerline). The really weird part is that if I lower the overall height of the prism, it generates in this area but messes up at the end of the interior wall (see attached) I'll look into emailing it to you, but I am not sure if I will be able to. |
Max Height over Base.
Now seeing this latest image and knowing that the other was meshed as a single layer, I would check for max height over base. (under global prism params) Perhaps you have this set to something like 0.5 and it is stopping the prism columns to prevent exceeding this value.
As always, thanks for the help Simon.
I think I got it coming out how I wanted it now. -Ryne |
How to delete pyramids without deleting tetras and prisms, meaning they are all a part of subset volume and are not separately defined. So how to delete them individually
1 Attachment(s)
Actually, if you are using a newer version of ICEM CFD, you can use the selection tool bar directly... On the right side of the Select Mesh Elements tool bar, you should see the options to Select all volume elements. If you have a more recent version (such as 14.5) you will see a pull down on that option that lets you check or uncheck what sort of volume elements you want it to select. You could unselect the tetrahedral and prism elements and then click the button to select just the pyramids... Attachment 18689 That said, I am not sure you want to delete all the pyramids... This will leave voids and uncovered faces. What is your actual goal? |
I am having 12.1 on one of the computers and 13 on the other .. Possibly I would be able to update to 14.5 as both are perpetual licences but that will take some time. I am having highly skewed tetras in the volume cos im growing nearly 40 layers by marching them. Also Im talking of meshes of nearly 30 million cells including prism ... so Ill take your advice and put on tetras in the tree and delete them :P i know my system will hang for a while :D ill switch to wireframe :) How do I grow tetras over the prism after deleting tetras? Is delauney possible in icem13?
