Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] single and twin screw geometry
Old   December 8, 2009, 03:55
Default single and twin screw geometry
imran baig
imran is on a distinguished road
How to use gambit to develop single and twin screw geometry
imran is offline   Reply With Quote
Old   December 8, 2009, 03:58
imran baig
i am interested in finding out method to develop single and twin screw geometry in gambit
Old   December 8, 2009, 04:02
Smile
imran baig
i need complete procedure
Old   December 8, 2009, 04:05
imran baig
i need complete procedure of developing single and twin screw geometry in gambit
Old   December 9, 2009, 07:59
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
create the face you want to extrude.
Then use the sweep face tool, type perpendicular, enable twist option, and finally give the right angle
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   December 10, 2009, 05:12
imran baig
Please narrate steps involved in creating faces of extruder .I am just beginner of software
Old   December 10, 2009, 06:55
-mAx-'s Avatar
Maxime Perelli
what kind of face do you have?
Old   December 28, 2009, 09:18
imran baig
i want first to develop 2D geometry of single and double screw extruder .Pl narrate steps in developing their geometry in gambit And further to mesh it using mesh superposition technique for simulation in fluent
Old   January 3, 2010, 08:39
Cool Twin screw geometry in gmbit
imran baig
I have created circular face for extrusion and swept the face giving type perpendicular and twist option and giving angle of 180 Volume is created with circular face at the other end too. I swept faces in small segments along small edges making zig zag volume with circular face after each segment. Please some body tells is it correct method? what is next?
Old   January 4, 2010, 01:50
-mAx-'s Avatar
Maxime Perelli
extract fluid domain.
Create a surrounding volume (containing your 2 screws) and substract this volume with the 2 others (boolean operation)
Old   January 9, 2010, 23:18
Question Simulation on mixing of two immiscible fluids in extruder
  #11
imran baig
I have created geometry of single screw extruder in gambit .Now i have to simulate two immiscible fluids. Is fluent 6 is applicable ? what sort of model is applicable? Two fluids are liquids one being highly viscous
Old   January 11, 2010, 01:55
-mAx-'s Avatar
Maxime Perelli
It should be ok with fluent.
Check Online Help
Old   January 20, 2010, 12:00
imran baig
i am using VOF model for mixing of Ethylene vinyl chloride and ethylene glycol Boundary conditions are moving reference frame of moving fluid and stationary wall inlet is pressure inlet ,the dimensions of single screw is 30mmdia &45 mm screw length on iteration flow is reversed and after 5 -6 iteration error pl help to getout of it
Thread Tools
Trackbacks are On
