-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [GAMBIT] iges (http://www.cfd-online.com/Forums/ansys-meshing/71003-iges.html)
mmentzos December 11, 2009 17:16
iges
Hi I try to export to .iges but
at Transcript I read:
HTML Code:
ERROR: Translation requires licence feature geom-trans.
ERROR: Translation failed.
What can i do for that problem?
Thanks
PSYMN December 30, 2009 11:53
It is saying that you don't have the license feature for that...
It has been a little while and no response from the CFD-Online community on this thread, so if you have not yet figured it out on your own, perhaps contacting ANSYS directly would be a good idea (I would start with ANSYS if I had any sort of licensing issue)...
Check you license and if you think you should have it, contact your IT department or ANSYS sales contact to look into it for you... You could also contact ANSYS tech support at techsupp@ANSYS.com to get better info about how this should behave and what you should be looking for in your license file...
