[ICEM] Export mesh to Gridgen
Old   December 24, 2009, 18:15
Default Export mesh to Gridgen
Ali
ali987 is on a distinguished road
Hi everyone,
I have grid in Ansys ICEM and I want to export it into Pointwise Gridgen and there is not such option in ICEM mesh export part(as I know...). How can I do that?
Regards,
ali987 is offline   Reply With Quote
Old   December 26, 2009, 03:22
Abou ali is on a distinguished road
You can export your mesh from ICEM to CGNS and then import the CGNS file in Pointwise Gridgen if it is permitted by this one, else try to find other file format common to these two softs.
Abou ali is offline   Reply With Quote
Old   January 2, 2010, 12:20
John Chawner
jchawner is on a distinguished road
Ali:
As Abou suggested, CGNS is always the first suggestion when moving data between two CFD codes. Since Gridgen's CGNS import is limited, I suggest exporting a CGNS file from ICEM and importing it into Pointwise.
You don't say whether your grid is structured, unstructured or hybrid but depending on the type any of several neutral formats might work. For example, structured grids could be shared using PLOT3D and unstructured grids may be shared using FieldView unstructured (although I'm not certain that ICEM can read it).
Hope this helps.
John Chawner / jrc@pointwise.com / www.pointwise.com
Blog: http://blog.pointwise.com/
on Twitter: @jchawner
jchawner is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
Two Ways FSI: How I can Export the Deformed Mesh back to the SolidWorks ahmadkermani CFX 6 March 8, 2016 03:29
Two Ways FSI: How I can Export the Deformed Mesh back to the SolidWorks ahmadkermani Main CFD Forum 0 August 13, 2009 22:02
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
mesh export Hossam FLUENT 1 May 5, 2006 12:28
