-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   Drawing a Semi cirlcle 3d (http://www.cfd-online.com/Forums/ansys-meshing/71231-drawing-semi-cirlcle-3d.html)
sambayo December 21, 2009 04:10
1 Attachment(s)
hi ,
i want to draw a semi circle then extrude it to form a half pipeline attached is a picture of what i want to draw any suggestions ?
thank you for you help
-mAx- December 22, 2009 02:22
whith gambit?
sambayo December 22, 2009 02:33
yes i am using gambit
-mAx- December 22, 2009 03:39
*create a circle (surface)
*create a diameter (edge)
*split the surface with the edge
*delete the entity you don't want
*sweep surface by selecting your semi-circle, and selecting the vector for the extrusion (you have created a volume)
that's it
