January 4, 2010, 07:59 |
problem with 3d-geometry
giacomo combariati
Rep Power: 16 |
Hi, I have a LNT (Low NOx traps) captured with a scanner 3d. I must divide the volume and surface of the LNT in some sections. The problem is that iges file is constituted of many surfaces. I thinked to merge surfaces to create a single surface, but then how i can to divide it?
January 6, 2010, 09:35 |
giacomo combariati
Rep Power: 16 |
I'm using Gambit. I should split the volume by surfaces to use boundary layer.
[ICEM] O-grid around wing geometry | Anorky | ANSYS Meshing & Geometry | 15 | November 27, 2017 13:43 |
[GAMBIT] problem to import iges file | jackr84 | ANSYS Meshing & Geometry | 1 | August 11, 2009 01:16 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Breaking in to the CFD Field | Jeffery Mitchell | Main CFD Forum | 4 | May 1, 2000 16:04 |
Time Taken for the Whole CFD Process | David | Main CFD Forum | 1 | March 20, 2000 16:47 |
