Home > Forums > ANSYS Meshing & Geometry
[ICEM] Error in Hybrid Mesh
Old   December 29, 2009, 07:04
Default Error in Hybrid Mesh
Ali
ali987 is on a distinguished road
Hi everyone,
We I merge Hex and tetrahedral regions following errors occurs:
I am trying to include edge 95 98 but vertex 95 isn't even in the region 1
error including edge 95 98
could not include quad
I am trying to include edge 4 7 but vertex 7 isn't even in the region 1
I am trying to include edge 6 5 but vertex 5 isn't even in the region 1
unable to include quad 2 (4 7 6 5)
but when I check the mesh(just by looking at it), it seems all elements are correct. what's that error??? It's very important for me to have a "pure" hex mesh which connect to the pure Tetrahedral meshes with pyramidal element. I mean I don't want to have, for example, tetrahedral elements in hex region.
Regards,
ali987 is offline   Reply With Quote
Old   January 1, 2010, 15:22
Default The rules...
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Tet Hexa merge is actually very robust in ICEM CFD. Try the tutorial for practice, but basically, the interface region can be any shape or curved or even be multiple separate interfaces. However, there are two rules for Hex-Tet merge that must be followed. I will try to make these clear, even if the error messages are not...
1) The entire surface of the interface parts must be used to merge. So if you are merging a Cylinder (circle) to a Cube (square), make sure the overlap (circle on both sides) are the interfaces and do not use the square side which is not completely shared by the cylinder.
2) The perimeter of the interface must be followed by both the Hexa and Tetra mesh… Line elements must be formed around the perimeter (or you get this error message). The tetra side is easy with the Octree tetra mesher, it just means you must have perimeter curves and the Octree mesh will naturally fit to the curves and create these line elements. If you imported the tetra mesh, you may need to extract these line elements or even fit it to the perimeter of the interface. It is usually easier for users to forget to generate these critical line elements on the Hexa side. ICEM CFD Hexa blocking is naturally patch-independent. If you want to explicitly extract a surface patch with line elements at the perimeter, you must associate the edges with the curves at the perimeter of the interface. Even if that edge and curve already appear “aligned”, make sure you associate them or you won’t get line elements and you will get this cryptic error message…
PSYMN is offline   Reply With Quote
Old   March 20, 2014, 13:46
Ke Wu
itsme_kit is on a distinguished road
Hi PSYMN
I got the same problem now
I attach a pic to show the interface I built
The mesh includes Hex, tetra and prism (where located at the bottom for boundary layers)
How can I solve this problem?
Really appreciate your help
Thanks in advance
itsme_kit is offline   Reply With Quote
Thread Tools
Trackbacks are On
Tgrid Hybrid mesh JSM FLUENT 2 December 5, 2007 00:03
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Gambit problems Althea FLUENT 21 February 6, 2001 08:05
hybrid mesh SC Hu FLUENT 1 December 23, 2000 16:40
zonal hybrid mesh Maolin Tu Main CFD Forum 1 October 21, 1999 10:10
