December 29, 2009, 16:19 |
Cd of a truck in a wind tunnel
Xavi
Hi guys,
First of all thank you. I am studying the Cd of a truck in a wind tunnel (Ignoring the effect of the wheels). BC: 1. speed of 80 km / h 2. Grid adaption to the y + (50 <y+ <500) 3. Moving Ground (case in relative motion format) ----------------------- GAMBIT & FLUENT 1. I subtracted the geometry of the truck, to get a single volume (this procedure is correct?) 2.I entire volume meshing (Scheme Elements: Tet / Hybrid, Type: TGrid, Spacing: 30 (interval count), Total elements: 339862) My question : 1. Need to create a finer mesh underneath the truck? if so, can I do in Gambit? (I've tried different ways but I failed meshing this area). 2. How do I know which is more correct meshing for these situations and what should be the number of elements to this mesh? 3. I have to create a BL in all walls of the truck? or with the option to "use grid adaption to the y + variable" is enough? 4. How would the distribution grid? Thanks again, |
wind tunnel results vs fluent | pixie | Main CFD Forum | 1 | August 20, 2009 08:02 |
how to consider perforated wind tunnel wall in CFD simulation | littlelz | CFX | 4 | June 11, 2009 05:51 |
Simulating a Göttingen type wind tunnel in FLUENT | Chris | FLUENT | 3 | December 4, 2006 17:33 |
Virtual Wind Tunnel in FLUENT | ND | FLUENT | 0 | April 7, 2006 07:43 |
Wind Tunnel Website now online | Mike Worthey | Main CFD Forum | 0 | June 6, 2000 02:27 |
