problem with 3d-geometry
Old   January 4, 2010, 07:59
Default problem with 3d-geometry
giacomo combariati
jackr84 is on a distinguished road
Hi, I have a LNT (Low NOx traps) captured with a scanner 3d. I must divide the volume and surface of the LNT in some sections. The problem is that iges file is constituted of many surfaces. I thinked to merge surfaces to create a single surface, but then how i can to divide it?
jackr84 is offline   Reply With Quote
Old   January 5, 2010, 10:52
Default Tools?
PSYMN's Avatar
Simon Pereira
What tools are you using?
Old   January 6, 2010, 09:35
giacomo combariati
I'm using Gambit. I should split the volume by surfaces to use boundary layer.
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 13:43
[GAMBIT] problem to import iges file jackr84 ANSYS Meshing & Geometry 1 August 11, 2009 01:16
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Breaking in to the CFD Field Jeffery Mitchell Main CFD Forum 4 May 1, 2000 16:04
Time Taken for the Whole CFD Process David Main CFD Forum 1 March 20, 2000 16:47
