December 8, 2009, 02:55 |
single and twin screw geometry
imran baig
Rep Power: 16 |
How to use gambit to develop single and twin screw geometry
December 8, 2009, 02:58 |
imran baig
Rep Power: 16 |
i am interested in finding out method to develop single and twin screw geometry in gambit
December 8, 2009, 03:02 |
imran baig
Rep Power: 16 |
December 8, 2009, 03:05 |
imran baig
Rep Power: 16 |
i need complete procedure of developing single and twin screw geometry in gambit
December 9, 2009, 06:59 |
Maxime Perelli
Rep Power: 41 |
create the face you want to extrude.
Then use the sweep face tool, type perpendicular, enable twist option, and finally give the right angle
In memory of my friend Hervé: CFD engineer & freerider |
December 10, 2009, 04:12 |
imran baig
Rep Power: 16 |
Please narrate steps involved in creating faces of extruder .I am just beginner of software
December 10, 2009, 05:55 |
Maxime Perelli
Rep Power: 41 |
what kind of face do you have?
December 28, 2009, 08:18 |
imran baig
Rep Power: 16 |
i want first to develop 2D geometry of single and double screw extruder .Pl narrate steps in developing their geometry in gambit And further to mesh it using mesh superposition technique for simulation in fluent
January 3, 2010, 07:39 |
Twin screw geometry in gmbit
#9 |
imran baig
Rep Power: 16 |
I have created circular face for extrusion and swept the face giving type perpendicular and twist option and giving angle of 180 Volume is created with circular face at the other end too. I swept faces in small segments along small edges making zig zag volume with circular face after each segment. Please some body tells is it correct method? what is next?
January 4, 2010, 00:50 |
#10 |
Maxime Perelli
Rep Power: 41 |
extract fluid domain.
Create a surrounding volume (containing your 2 screws) and substract this volume with the 2 others (boolean operation)
January 9, 2010, 22:18 |
Simulation on mixing of two immiscible fluids in extruder
#11 |
imran baig
Rep Power: 16 |
I have created geometry of single screw extruder in gambit .Now i have to simulate two immiscible fluids. Is fluent 6 is applicable ? what sort of model is applicable? Two fluids are liquids one being highly viscous
January 11, 2010, 00:55 |
#12 |
Maxime Perelli
Rep Power: 41 |
It should be ok with fluent.
Check Online Help
January 20, 2010, 11:00 |
#13 |
imran baig
Rep Power: 16 |
i am using VOF model for mixing of Ethylene vinyl chloride and ethylene glycol Boundary conditions are moving reference frame of moving fluid and stationary wall inlet is pressure inlet ,the dimensions of single screw is 30mmdia &45 mm screw length on iteration flow is reversed and after 5 -6 iteration error pl help to getout of it
