[ICEM] Error Meshing Edge!
Old   January 22, 2010, 08:04
Question Error Meshing Edge!
Monica
campos is on a distinguished road
While I am making the mesh, it appears the message below:
"bad params in create_edge_pars
A minor internal error has occurred.
You may continue to work but if problems arise they may be related to this error.
Try using the check/fix function to fix the problem
The following message was designed to aid developers fix the problem:
error meshing edge 496 497"
I've already selected the nodes number, spacing 1 and mesh law.
What does this message mean? Has someone already had this problem?
campos is offline   Reply With Quote
Old   July 19, 2010, 09:07
Alphonse is on a distinguished road
I have that massage after I rotated blocks and geometries.
Alphonse is offline   Reply With Quote
Old   July 20, 2010, 09:25
Default Minor Error.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yes, it is a minor error. They were really only intended for developers and won't stop you from continuing. At 13.0, we have added an option to hide these minor errors so they don't worry you for nothing...
I am not sure exactly what it is complaining about, probably that it can't satisfy all your edge parameter requirements...
You could find the edge between those end nodes and check out its specific edge params if you wanted, or you could just keep on blocking.
PSYMN is offline   Reply With Quote
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 14:18
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
[Commercial meshers] Star mesh import problem chris1980 OpenFOAM Meshing & Mesh Conversion 20 May 8, 2006 01:07
