Home > Forums > ANSYS Meshing & Geometry
[ICEM] meshing 2d geometry with ogrid
Old   January 22, 2010, 10:55
Default meshing 2d geometry with ogrid
Vesselin Krastev
vkrastev is on a distinguished road
Hello, I have a problem with generating a 2d structured mesh around a solid object by using the "ogrid" option in ICEM 10.0. The case in question is made up by the object itself, immersed in a rectangular ambient with inflow and outflow sections, and the solver I want to use is Fluent (in particular I need to obtain the mesh in a .msh format). Can someone of you give me a little help (maybe redirecting me to a good tutorial case)?
Thank you in advance
vkrastev is offline   Reply With Quote
Old   February 10, 2010, 02:35
Default Re:
jeevan kumar
jeevankumarb is on a distinguished road
May be if you can post the image of the geometry will be helpfull to understand. And can help u with the blocking.
thank you
jeevan
jeevankumarb is offline   Reply With Quote
Old   February 10, 2010, 05:48
Vesselin Krastev
The geometry was simply made up by a rectangular profile. Actually now I have resolved my problems with the usage of Icem, but If I can give you an advice this software is not (in general) the best choice for meshing complex geometries...By the way, thank you for the reply
Old   February 13, 2010, 02:08
Default Walk a mile first...
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
ICEM CFD works very well on complex geometries. In fact it is probably the most advanced structured hexa mesher available. We have users working on everything from aircraft and automobiles to skeletons and jet engines.
But there is a learning curve and you should probably do at least one tutorial.
PSYMN is offline   Reply With Quote
Thread Tools
Trackbacks are On
IGES/IGS format geometry file for icem meshing littlelz Main CFD Forum 0 May 27, 2008 18:24
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
Meshing the geometry Vidya Raja FLUENT 0 February 26, 2006 20:44
Meshing Film cooling geometry Janendra Telisinghe CFX 1 January 31, 2006 07:16
meshing geometry in gambit soundar FLUENT 1 January 7, 2005 03:59
