-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] mesh creation (http://www.cfd-online.com/Forums/ansys-meshing/72362-mesh-creation.html)
Birkov February 3, 2010 08:02
mesh creation
Hi to all,
I have question about mesh creation. I imported data from STL (box in box) file to ICEM. I would like to create mesh only between boxes (not in box inside) but I can't figure out how to do it. I checked manual and there is almost what I want, but only if I want just box inside all everythink.
Can anybody help?
Thank you very much.
B.
EDIT: I tried different file type (parasolid) and it works how I expected. But if it's any way how to solve problem which I described I will be happy. Thank you.
rwryne February 3, 2010 08:40
Make sure you create a material body within the area you want to be meshed. (It is the button to the right of the mesh button in the Geometry tab)
Birkov February 3, 2010 09:00
As I wrote I chose different file format and it works. I will continue on this way.
Thanks for quick reply.
