-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Blade passage block mesh in ICEM (http://www.cfd-online.com/Forums/ansys-meshing/72531-blade-passage-block-mesh-icem.html)
Attesz February 9, 2010 07:48
Hi all,
I'm doing a cf.compressor simulation. To get the best results, i want to generate a structured, blocked hexa mesh in ICEM, only for a blade passage. Previously I made tetra mesh for this, but I'm beginner in blocking. I'm doing now the tutorials, but I think, the blocking of the blade passage is more complicated. Have anyone a tutorial, or just a good image about a hexa mesh in cf. compressor, cp.turbine., cf.pump or same turbomachinery, something to start with?
Thanks a lot,
Attesz
jeevankumarb February 10, 2010 02:31
RE:
Dear Attesz
If you can send the geometry, i will do the blocking and will create a ppt and will send you.
Thank you
jeevan
Attesz February 10, 2010 07:04
Dear jeevan,
thank you for your reply. I'm working on the geometry now, when I'm ready, I send it!
Thanks again,
Attesz
PSYMN February 13, 2010 02:10
Stator
There is also a "stator" tutorial in the basic tutorial set.
Attesz February 13, 2010 05:53
Thank you, I've already made it since I wrote this post.
Regards,
Attesz
