[ICEM] How a surface can be splitted by another one?
Like Tree2Likes
  • 2 Post By PSYMN
Old   December 5, 2010, 09:38
Default How a surface can be splitted by another one?
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
This feature does not seem to be in ICEM. I did not manage to find it. Is this why the 'build topology' can not split intersected surfaces (Only T-connected surfaces is processed correctly).
Zeppo is offline   Reply With Quote
Old   December 6, 2010, 09:07
Default Intersection Curve
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Build topology splits surfaces with curves...
For surface to surface intersections, you first need an intersection curve.
You can create this under the curve creation tools.
Once you have the intersection curve, then run build topology or split surface with a curve.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
kkpal and bouzari2012 like this.
PSYMN is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
