Home > Forums > ANSYS Meshing & Geometry
Hull geomerty Import
Old   February 15, 2010, 12:31
Default Hull geomerty Import
Christopher Smith
chriscross07 is on a distinguished road
Hi All,
I am able to use CFX to a basic level so sorry if i am not using the correct terminology.
I am trying to model a hull in a free surface in order to study the effect of fitting spray rails.
I have modeled the hull shape in Maxsurf and then imported the geomertry into Rhino to fit the spray rail. The model is then imported into Designmodeler to assign a domin around the hull. I have imported the files as iges.
I'm having real problems meshing using CFX mesh.
Can anyone give me the best process to follow to go about successfully importing the model and being able to mesh and run a simulation.
Many thanks
chriscross07 is offline   Reply With Quote
Old   February 16, 2010, 13:51
Default Baffles?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Are the spray rails zero thickness baffles?
PSYMN is offline   Reply With Quote
Old   February 16, 2010, 14:17
Christopher Smith
No it is basically a rectangular box section that extends 7m form the bow of the hull.
I am presuming and please correct me if I'm wrong that if is was a zero thickness bafel that it would require some thickness in order to be able to mesh the geometry.
Old   February 18, 2010, 16:43
Default Baffleing
PSYMN's Avatar
Simon Pereira
Right, this problem is fixed at 13.0, but at 12.1 and earlier, ANSYS meshing did not handle zero thickness baffles well.
If you had baffles then I could guess that was your problem.
Beyond that, your question is a bit too vague. I guess I could suggest trying the tutorials...
Thread Tools
Trackbacks are On
Lift on the Hull hashem_1064 CFX 10 May 28, 2009 18:23
Mesh Motion pitch on a hull Seb CFX 1 February 23, 2009 14:04
Pressure distribution along hull sam CFX 1 September 13, 2008 17:09
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
I-DEAS CAD data import with boundary conditions Yunus FLUENT 2 March 14, 2001 15:45
