March 30, 2011, 17:49 |
FSI grid
Rep Power: 15 |
Hi, I haven't been using ICEM for all that long. Basically I have a tank of water with a structure located near the bottom that should be immersed from all sides in the fluid. Up till now I have been only modelling the tank with no structure using blocking and hex elements, but now with the added structure I just don't know how to go about creating this mesh. Can I use my old mesh with only fluid and just delete the cells where my structure is?
April 2, 2011, 10:26 |
Simon Pereira
Rep Power: 47 |
If you are doing FSI, then you will need the cells in the structure... (can't just delete them)
Depending on the topology, you can split (the blocking) the solid portion out of the fluid portion and just assign those blocks to a solid material.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 16:43 |
