-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [Gambit] inverted elements / negative volume (http://www.cfd-online.com/Forums/ansys-meshing/72883-gambit-inverted-elements-negative-volume.html)
jack1980 February 20, 2010 12:54
In Gambit I ran into a strange problem. When I mesh a certain face, the grid is out of the plane of the face. I get the following message:
"ERROR: ACIS error 43001 : coincident face_face_ints with different body vertices"
The strange thing is that I had no difficulties at all with coarser meshes for the exact same geometry.
However, I can still mesh the associated volume (with some highly skewed elements) and write a .msh file. I can read it in Fluent, but the grid check fails: the problem appears to be that I have 6171095 right-handed and 26 left-handed faces. Still, in Fluent the grid contains the correct number of elements. I can initialize, but when I try to iterate Fluent returns:
"Error: divergence detected in AMG solver: pressure correction"
So, I'm pretty sure something is wrong with this face. It appears to cause some troubles, such that I can't iterate in Fluent.
Furthermore, if I decrease the element size at the (distorted grid) face edge, Gambit will mesh the face but won't mesh the associated volume anymore:
"inverted elements (negative VOLUME)"
I really hope somebody can help me out here. Especially since the results on the coarser grids looked so promising.
Thanks!
Update:
I tried TUI: /grid/modify-zones/repair-face-handednes
This returned: "Left-handed faces can't be converted to right-handed faces. All face nodes have the right order, but the mesh probably contains non-convex cells."
-mAx- February 22, 2010 02:50
I would try to split your face which gives you trouble.
Enforcing the presence of edge(s) on the surface may help and solve your problem.
Already experienced this case
