[ICEM] Exporting good ICEM mesh to Fluent results in poor quality mesh |
September 19, 2018, 13:35 |
Rep Power: 9 |
Hi guys. I am meshing a cylinder with a disc attached on it in ICEM. I have some refinements in it (3 levels but all are 2:1 - so at the deepest level the mesh is 8 times finer than the unrefined). All quality measures showing no problem but when i am exporting the mesh to Fluent some left and right handed faces appear and elements with high aspect ratios 3.8e+04 appear. Furthermore, the minimum ortho skew is 1 and the minimum ortho quality in Fluent is 0. When I am checking the Fluent aspect ratio in ICEM it says 3.8e+01. What can happen during the export to Fluent that the mesh gets destroyed so badly. As ICEM is giving me no errors except the usual uncovered faces i don't know how to solve this problem. Maybe someone of you guys can help me with your experience. Thanks!
September 24, 2018, 06:52 |
Sebastian Engel
Rep Power: 20 |
Fix the uncovered faces first.
You most likely find something in the forum search with the terms "icem uncovered faces" Compare the definitions of ICEM and Fluent quality criterions. Their calculation can be different. Last edited by bluebase; October 10, 2018 at 06:42. Reason: savin the search link was a flawed idea, put explicit search terms |
October 15, 2021, 06:53 |
Alessandro
Rep Power: 7 |
Hi @balrog_f. Have you solved this problem?
October 17, 2021, 02:43 |
#4 | |
Sebastian Engel
Rep Power: 20 |
It's likely that balrog used the search function and was a bit more persistent. She/he might have found posts such as Problems with export 2D mesh from ICEM to FLUENT |
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM | guxin7005 | FLUENT | 2 | June 27, 2016 21:41 |
Ansys mesh for FLUENT software giving unrealistic results, while GAMBIT mesh is fine | kbhamidipa3 | FLUENT | 0 | November 30, 2012 15:52 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
Importing ICEM mesh to Fluent | mr_stoked | FLUENT | 1 | June 25, 2010 03:24 |
Import ICEM Mesh to Fluent | Fluent Beginner | FLUENT | 5 | June 23, 2004 00:27 |
