[ICEM] Ortho smoothing problem
Old   May 1, 2011, 14:06
Default Ortho smoothing problem
Lorenzo Mazzei
Mazze[ITA] is on a distinguished road
Hi all, I'm working on a turbine blade simulation and I found some problems achieving convergence. I decided to smooth the mesh (hexa multi-block structured), but the pre-mesh orthogonality smoothing freezing the fluid parts (boundaries) caused negative volumes. So I tried a compromise solution freezing each part (solid and fluid) with the respective first layer, reaching the result of a smoothed mesh with zero n.v. (except for the superficial mesh and the first layer, obviously). The main problem is the uncontrolled ratio between the first frozen layer and the second smoothed one.
Does anyone know a way to smooth the mesh controlling the ratio of the first layers (the shear layer)?
Mazze[ITA] is offline   Reply With Quote
Old   May 3, 2011, 02:17
Lorenzo Mazzei
I didn't find the right solution, but I controlled the problem freezing about 20 layers on the surface of the blade. The high ratio is still there, but further from surface.
orthogonality, ratio, smooth
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Hexa smoothing (ICEM CFD 10.0) CFDworker CFX 3 November 2, 2005 10:23
