[ANSYS Meshing] Error: Sheet bodies are not supported by auto inflation
Old   November 9, 2014, 18:24
Default Error: Sheet bodies are not supported by auto inflation
egge24 is on a distinguished road
I'm trying to mesh an open channel with a complex bathymetry to assess flow field. When I try to use Inflation to create represent well the boundary layer I get the following error:
"Sheet bodies are not supported by auto inflation"
Does anybody knows what is the definition of sheet bodies? and, how I can solve this problem?
The figure below shows the modeling domain. The upper bound has a velocity inlet boundary condition (bc), the bottom of the channel has a wall bc, the outlet a pressure outlet bc, and the top face, hidden in the figure, a symmetry bc.
Thank you!
egge24 is offline   Reply With Quote
Fluent diverges when using inflation layers ziggo FLUENT 4 August 9, 2013 12:11
Large Valve Flow Analysis - Inflation Problem sercan85 ANSYS Meshing & Geometry 2 June 1, 2010 14:02
Inflation Gab CFX 6 August 24, 2005 22:45
