March 4, 2010, 22:52 |
Importing Model from DesignModeler into ICEM
Joshua Counsil
Rep Power: 17 |
Hi -
I cannot find a way to import a DesignModeler geometry into ICEM. I've checked several sources that keep pointing to parasolid, etc. Help would be greatly appreciated. Josh |
March 5, 2010, 09:31 |
#2 | |
Ryne Whitehill
Rep Power: 18 |
It will create a .prj, .tin, and .uns, all you will need is the .tin. |
March 5, 2010, 09:45 |
#3 | |
Ryne Whitehill
Rep Power: 18 |
Sorry for the second reply, but I just stumbled across one of PSYMNs post showing an alternate method of doing this:
March 5, 2010, 10:12 |
Simon Pereira
Rep Power: 47 |
Thanks Rwryne,
Yes, there are lots of ways. The easiest is just using the File => Workbench Readers option. However, this does require you to install Workbench... Which shouldn't be a problem since you have Design Modeler. Best regards, Simon |
March 5, 2010, 10:30 |
#5 | |
Ryne Whitehill
Rep Power: 18 |
I am trying to use this direct Workbench reader but am running into a units issue. My CATIA file is in inches, my default unit set in workbench is in inches, but it keeps importing the file in mm. I even tried switching the Part, Sizes option to "from tetin" and selecting a tetin with inches, to no avail. Any idea? |
March 5, 2010, 13:11 |
#8 | |
Ryne Whitehill
Rep Power: 18 |
well the other issue I am having is the scaling is not working for me. I use the select all for the selection with a X,Y,Z factor of .039whatever, but nothing comes of it. It thinks for awhile, and shows back up still as mm. The only thing that I haven't played with is the center point, but it doesn't seem like that should affect anything. |
March 9, 2010, 14:52 |
#10 |
Joshua Counsil
Rep Power: 17 |
Thank you very much. I spent hours playing around with the various programs and researching online to try to solve this problem.
It has imported successfully. I'll probably have problems later, but this is great for now. Thanks again! |
Importing SolidWorks Model DIRECTLY into openfoam | bgood44 | OpenFOAM | 9 | January 20, 2020 06:47 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Importing a mesh from ICEM | Waseem Siddique | Siemens | 14 | February 9, 2009 05:05 |
simulation results for k-w model and SST model | Li | CFX | 7 | June 29, 2007 04:19 |
Importing file from Parasolid to ICEM | prateek jain | CFX | 0 | May 28, 2007 01:16 |
